Roshen 0 Report post Posted May 1, 2011 (edited) Installing rear shocks from the H&R cupkit, attached to each of the rear is a washer, as i the pic? anybody can advise where they go? cars a 86 e30 325i -Roshen Edited May 2, 2011 by Roshen Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted May 2, 2011 Under the bolt head... not between the shock and hub Quote Share this post Link to post Share on other sites
Roshen 0 Report post Posted May 3, 2011 Under the bolt head... not between the shock and hub thanks Glen, also when the shocks in front came out there was oil in the sleave that the shock sits in.. not sure if i leave the oil in there or drain it out, as the how-to i was following was not clear. Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted May 3, 2011 Leave the oil in, its acts as a damper. Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted May 3, 2011 Leave the oil in, its acts as a damper. No.. its there to transferr heat from the shock insert to the leg so the insert gets cooling. We usually change it with ATF fluid Quote Share this post Link to post Share on other sites
