alijanjan 3 Report post Posted May 25, 2011 (edited) Hi everyone I think I may need new rotors for my e38 What happens is as soon as I brake( specially if u don't brake that hard) the car shakes, quiet badly only when I'm driving over 80k The strange part however is that it only started doing it after I changed a tyre, double checked the balance, all ok Any thought? Cheers Edited May 25, 2011 by alijanjan Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted May 25, 2011 (edited) worn out brake reaction arm (or thrust arm) bush or ball joint or wrapped brake rotors etc part 5 or 6 http://bmwfans.info/parts/catalog/E38/Seda...pport_wishbone/ Edited May 25, 2011 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 25, 2011 The strange part however is that it only started doing it after I changed a tyre, double checked the balance, all ok Any thought? Cheers Are the wheels hubcentric ?? or have you lost the hubcentric ring ?? Quote Share this post Link to post Share on other sites
alijanjan 3 Report post Posted May 26, 2011 Are the wheels hubcentric ?? or have you lost the hubcentric ring ??I'm not too sure, will have to check, can this cause the problem? Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted May 26, 2011 I'm not too sure, will have to check, can this cause the problem?yes your wheel will not be centred on the hub .will cause it to wobble al the time. did you get the trust arm bushes checked as they are a heavy car and they wear these out all the time Quote Share this post Link to post Share on other sites
