pureboiracer 0 Report post Posted May 30, 2011 Hey guys, need some stuff for my e30. its a 1987 pfl 320i manual. need parts 4, 7 and 8 from the following link. http://www.realoem.com/bmw/showparts.do?mo...hg=51&fg=20 need parts 16, 18 and 19 from the following link. http://www.realoem.com/bmw/showparts.do?mo...hg=51&fg=20 also need an m20 flywheel, good condition m20 rear lights, two front brake pipes, (from the master cyl to the wheel arches, steel pipe.) a master cylinder that fits either the following two requirements. Brake master cylinder 19,05/20,64MM ? 34311154263 Brake master cylinder 19,05/20,64MM ? 34311156273 the front half of a standard m20 exhuast, from the flange at the manifold to the 1st factory muffler. an open 4.1 small case diff. the metal brackets that hold the D-bushes for the front sway bar. That is all i can think of at the moment, i will try bmw for the clips etc and will go round to local wreckers but am too busy over the next couple of weeks to get out the house much so i figured i will just ask on here in the meantime. any help appreciated. thanks oli Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3027 Report post Posted June 6, 2011 I have loads of trim bits and piles of clips and attachments to cover the first set of numbers. Don't have the clips for the second list of numbers, but a big dop of sikaflex replaces each of those quite well I have found the master cylinders I have, will check the part numbers to see if they are suitable for you. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted June 6, 2011 cheers john, will try and head up your way in the next couple of weeks Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted June 6, 2011 Get my text today? Quote Share this post Link to post Share on other sites
rjac001 0 Report post Posted June 6, 2011 Hey guys, need some stuff for my e30. its a 1987 pfl 320i manual. need parts 4, 7 and 8 from the following link. http://www.realoem.com/bmw/showparts.do?mo...hg=51&fg=20 need parts 16, 18 and 19 from the following link. http://www.realoem.com/bmw/showparts.do?mo...hg=51&fg=20 also need an m20 flywheel, good condition m20 rear lights, two front brake pipes, (from the master cyl to the wheel arches, steel pipe.) a master cylinder that fits either the following two requirements. Brake master cylinder 19,05/20,64MM ? 34311154263 Brake master cylinder 19,05/20,64MM ? 34311156273 the front half of a standard m20 exhuast, from the flange at the manifold to the 1st factory muffler. an open 4.1 small case diff. the metal brackets that hold the D-bushes for the front sway bar. That is all i can think of at the moment, i will try bmw for the clips etc and will go round to local wreckers but am too busy over the next couple of weeks to get out the house much so i figured i will just ask on here in the meantime. any help appreciated. thanks oli Dude I'v got a M20B25 87' low Ks $400 for the complete engine + a box of beer for delivery Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted June 6, 2011 Thanks but have a motor already. andy i did i will reply now. Quote Share this post Link to post Share on other sites
