dsa56 0 Report post Posted June 2, 2011 (edited) Just wondering on my E39 i've got the standard TV function which i assume will stop working when the government switches the TV broadcasting to digital. Is there a fix for this issue at all... Edited June 2, 2011 by bmw nz Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted June 2, 2011 it wont work , unless you can get a digital tv receiver unit to adapt into it. but i wouldn't worry about it for a while i think they will keep the old analog system going for a few more years yet. nothing worth watching on those chanels anyway unless its top gear etc Quote Share this post Link to post Share on other sites
dsa56 0 Report post Posted June 2, 2011 Thanks for that Brent ..... Guess you are right... Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted June 2, 2011 (edited) I guess you could get something like this and run it to the AV input on your video module. Digital TV Tuner Although that would only be Terrestrial Freeview and I am not 100% sure NZ system is compatible ?? BTW - Good to hear from you again Sammi - you seemed to disappear after the CHCH earthquake ! Edited June 2, 2011 by camera doctor Quote Share this post Link to post Share on other sites
dsa56 0 Report post Posted June 2, 2011 Hey Thanks Greg.. I'll follow up on the link you send... and yes i haven't been online much after the quake but now all up and running still waiting to buy my DICE unit too...once i have that might contact you or come down your way for a drive... Thanks again Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 2, 2011 Just wondering on my E39 i've got the standard TV function which i assume will stop working when the government switches the TV broadcasting to digital. Is there a fix for this issue at all... Exactly the same as your TV at home When the analogue TV transmitter is turned off, the analogue TV receivers will have no more signal to receive Solution: add a settop box Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted June 2, 2011 (edited) Sami, I also found this Bimmersport thread So this one MAY work ?? EBay Edited June 2, 2011 by camera doctor Quote Share this post Link to post Share on other sites
Crazy Dave 0 Report post Posted June 3, 2011 That one off Ebay looks like a starter, but, as has been well pointed out here, avoid the MPEG2 ones. On a related subject my 2001 E39 when the TV is set to the AV in channel shows MUTE at the bottom of the screen. Video works if you stick something in the AV port but no sound. Anyone know how the MUTE for the AV channel works or more importantly how to turn the MUTE off. Cheers Dave Quote Share this post Link to post Share on other sites
Dogballs 123 Report post Posted June 3, 2011 That one off Ebay looks like a starter, but, as has been well pointed out here, avoid the MPEG2 ones. On a related subject my 2001 E39 when the TV is set to the AV in channel shows MUTE at the bottom of the screen. Video works if you stick something in the AV port but no sound. Anyone know how the MUTE for the AV channel works or more importantly how to turn the MUTE off. Cheers Dave The Mute works automatically. If it is staying on, the connection is not right - incorrect wiring / jack of whatever you plugged into it.. you will note the tv channels that aren't tuned to anything or very weak signal will mute also.. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 4, 2011 A good use for the analogue TV unit: Buy a cheap wireless video camera, that broadcasts a small signal on a analogue TV channel Set it up in the front or rear of the car inside your garage so you can see how close you park inside the trailer on the rear of the trailer etc And the TV will receive it as a std analogue TV channel Quote Share this post Link to post Share on other sites
swauto 4 Report post Posted June 30, 2011 Just wondering on my E39 i've got the standard TV function which i assume will stop working when the government switches the TV broadcasting to digital. Is there a fix for this issue at all... We are working on the fully integrated DVB-T solution for E46, E39, E53, E83, E85 OEM Wide sreen, also fully integrated DVB-T solution for E60,E90,E70,F10,F01 idrive system. This will allow us to use BMW OEM screen and and control for NZ freeview. Still doing the testing at moment, will provide more information once confirmed Quote Share this post Link to post Share on other sites
swauto 4 Report post Posted July 3, 2011 We are working on the fully integrated DVB-T solution for E46, E39, E53, E83, E85 OEM Wide sreen, also fully integrated DVB-T solution for E60,E90,E70,F10,F01 idrive system. This will allow us to use BMW OEM screen and and control for NZ freeview. Still doing the testing at moment, will provide more information once confirmed Addition to that, we will have some exciting solutionsfor fully integrated USB media player which can be added into older BMW OEMwide screen system or newer idrive system and even latest idrive system. We are the only company who stay on top of latest retrofitting solution forEuropean cars. We are trying to make everything possible for your car entertainmentsystem, and more importantly, OEM integration is our focus. Quote Share this post Link to post Share on other sites
swauto 4 Report post Posted July 9, 2011 I found this video that shows the ibus based MPEG II DVB-Tuner on youtube. Our ibus based MPEG 4 DVB-T Tuner will work exactly the same way as this one. Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted July 10, 2011 Cool, keep us up to date ....... Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted March 19, 2012 We are working on the fully integrated DVB-T solution for E46, E39, E53, E83, E85 OEM Wide sreen, also fully integrated DVB-T solution for E60,E90,E70,F10,F01 idrive system. This will allow us to use BMW OEM screen and and control for NZ freeview. Still doing the testing at moment, will provide more information once confirmed *thread resurrection* any news on a DVB-T solution for E90 with CCC system? Quote Share this post Link to post Share on other sites
swauto 4 Report post Posted April 18, 2012 *thread resurrection* any news on a DVB-T solution for E90 with CCC system? will be released by July to August this year Quote Share this post Link to post Share on other sites
mynbmr 225 Report post Posted July 1, 2012 Can any one please recommend what aerial to use for my TV in my truck, They've given me a sky dish and decoder but i dont really need that , i just want something digital for receiving tv 1,2,3 and prime. The sky dish they've given me you have to put out side and manually turn it, but i want something that is permantely fit on the truck. Cheers Hans Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted July 5, 2012 Can any one please recommend what aerial to use for my TV in my truck, They've given me a sky dish and decoder but i dont really need that , i just want something digital for receiving tv 1,2,3 and prime. The sky dish they've given me you have to put out side and manually turn it, but i want something that is permantely fit on the truck. Cheers Hans Digital TV in NZ is in the UHF band. Any wide-band UHF antenna will do, and these are available from many car audio shops as a stick-on window antenna. Use a TV tuner with diversity if you wish to have TV reception on the move Quote Share this post Link to post Share on other sites
