_Matt_ 42 Report post Posted June 7, 2011 intermittent no longer works, I need a new wiper control unit that's located in the fuse box. Any in Chch? cheers. Ill try the usual wreckers if no luck here. Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted June 8, 2011 Part number: 61311386978 Number 3 are the relays from an e30 the same? Quote Share this post Link to post Share on other sites
polley 916 Report post Posted June 8, 2011 Yes. http://www.realoem.com/bmw/partxref.do?part=61311386978 Quote Share this post Link to post Share on other sites
BM WORLD 1264 Report post Posted June 8, 2011 got one 021433600 brenta1@clear.net.nz Quote Share this post Link to post Share on other sites
tcbaurpower 5 Report post Posted June 9, 2011 I should have one, I have the fuse box from an 87 e28. Will check it tonight. Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted June 10, 2011 I should have one, I have the fuse box from an 87 e28. Will check it tonight. cheers, otherwise ill just pop into a wrecker since the e30s are the same. Quote Share this post Link to post Share on other sites
tcbaurpower 5 Report post Posted June 15, 2011 Hey Matt. I have the unit, it is the same as in the picture for number 3. The number on it doesnt seem to be a part number tho. Let me know if you still need it. Cheers Adam. Quote Share this post Link to post Share on other sites
