pjay
E30 Sway bar sizes
I found this while trawling the internet, may be helpful for others:. Feel free to correct anything that may be in correct, I am just copy/pasting.
318i (m10): Front: 18mm Rear: none
318is (m42): Front: 20mm Rear: 12mm
318ic (m42): Front: 21mm Rear: 12mm
320i/323i: Front: 18.5mm Rear (Sports Suspension): 12mm
320i/323i(-03/85): Front (Bilstein): 18.5mm Rear (Bilstein): 12mm
320i/323i(03/85-): Front (Bilstein): 20mm Rear (Bilstein): 14.5mm
325e(pre 9/86): Front: 18.5mm Rear: 12mm
325e (9/86): Front: 20mm Rear: 12mm
325i (m20): Front: 20mm Rear: 12mm
325is (m20): Front: 20mm Rear: 12mm
325ic (m20): Front: 21mm Rear: 12mm
325ix (M20): Front: 17mm Rear: 14.5mm
325ix Touring(M20): Front: 18mm Rear: 14.5mm
M3 (s14): Front: 19mm Rear: 14.5mm
It seems like you got Bilstein when you had "Sports Suspension" + "M Technic". As far as I understand, if you ordered "Sports Suspension" + "M Technic" on a -03/85 car, you still got the same dimensions on the antirollbars as the standard ones.
AC Schnitzer: 20mmF 16mmR
Racing Dynamics Early Style (adjustable): 22mmF 16mmR
Racing Dynamics Late Style (adjustable): 22mmF 19mmR
Eibach: 20mmF 16mmR
H&R (adjustable): Front: 22mm Rear: 18mm
Racing Dynamic: 22mmF 16mmR
Ireland Engineering....22mmF 19mmR
Whiteline 24mm front 16mm rear
Eibach: Front: 20mm Rear: 16mm
Suspension Techniques: Front: 22mm Rear: 19mm
Ireland Engineering (adjustable): Front: 25mm Rear: 22mm
M-Technik: Front: 20mm Rear: 14.5mm
Edited by Pjay
My 320i has no rear sway bar and a friends m40 318 had none either.
I've seen 14mm rear sway bar bushes around, but not 14.5mm. simple mis measurement by others, or is there actually a 14.5mm and 14mm sway bar?
