ED1RTY
E30 Rare Bits
Are the front spots in intact condition? Are they still available?
  -Oli- said:
do you have an m20 flywheel by chance?
m20 flywheel 100$ fl or 2L only no 2.5 with pick up sensor
  jonno said:
hay do you have a standard exhaust??
Gone
  Shady said:
Whats the upgraded boot trims? Can you show a photo?
Will post pics when I have time I'm sure we all know what the boot of an M325 looks like! They are just exc cond. m325i boot trims.
Gone, Sorry
If the boot trims are the same as all E30's then OK. But you say "upgraded" so thought that meant they were a bit different or something....just wondered. Also thought they may be the boot LID trim panel.
I have a boot lid trim panel. It is just a full set of boot carpet including the foam liner which is usually missing.
Hey do you have flywheel and clutch?
How much?
