BMRBOI 8 Report post Posted June 13, 2011 (edited) Hi guys, I will be putting a new engine into my 1992 e36 325i (non-vanos) within the next few months. I am currently gathering parts together to make life easier. I left my build list at work so i will post that tomorrow when i get the time. The car im aiming to build will be a street car which i can take to the track. I would like some advice/ help in choosing parts which i will require for my build. I am currently looking at buying m3 engine mounts, new tranny mounts and ali thermostat housing from pelican parts. If i was to purchase oil seals/ gaskets which ones are prone to leaking? Baring in mind shipping weight. Cheers Niroy Edited June 13, 2011 by BMRBOI Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted June 13, 2011 Not engine parts but: Cross brace, Spacer Set for Rear Trailing Arm Bushings, basically renew any bushes that will tighten up the suspension. Once your have your list together, I would check out Turner Motorsports, then email your list to Doug Mahar [[email protected]] get a quote off him as I have found their shipping cost are the cheapest and fast as they use FedX (with no mark up), Pelican use UPS. Quote Share this post Link to post Share on other sites
BMRBOI 8 Report post Posted June 13, 2011 (edited) Already done Engine KnN Cold air intake and air box AC delete 16†electric fan and controller with temp Suspension & Subframe Derlin offset caster bushes for front control arms M3 evo 23.3mm sway bar and drop links Sachs sporting suspension and springs Ultra racing front and rear strut braces Ruff rear shock mounts and reinforcement plates Ruff subframe bush kit & oem subframe diff bush Reinforced subframe with m3 plates welded to chassis Reinforced swaybar mounts on subframe carrier Lemforder trailing arm bushes M-spec 18mm sway bar Other Momo steering wheel Sports gear knob Motorsport tail lights Frosted indicators on front Panasonic /JVC sound install Recovered roof lining and rear parcel tray 18x8 replica BMW wheels Wanted to do Engine Replace m50 with low kms engine Replace sump gasket and weld oil pump nut Replace water pump, thermostat (80º) and housing Rear crank seal Oil cooler setup weld lugs onto filter housing for lines M20 flywheel, starter motor, clutch and e21 throughout bearing Replace engine and gearbox mounts Replace drive shaft donut Brakes Install goodridge lines Install genuine bmw pads Replace rear rotors and calipers with e36 328i items Motul 5.1 fluid Suspension & Subframe Install steering rack limiters Install new tie rods Install meyle heavy duty ball joints Install new centre joints Install SPC camber plates Replace with rear camber arms Replace with rear trailing arm limiters Install 3.15 lsd and new diff bushes Cosmetic Replace bonnet Replace nose cone Replace front bumper (motorsport) Other Remap ECU Replace faulty body control module and rear window switch. (parts which say install are things i already have, parts which say replace are the ones i require) Edited June 13, 2011 by BMRBOI Quote Share this post Link to post Share on other sites
BMRBOI 8 Report post Posted June 13, 2011 Thanks mate, yeah my suspension is my first stop! I have aimed at replacing most bushes i consider to be worn out or sloppy. Already i can notice the difference. In general i am using pelican parts mainly because of how cheap some of the parts are, also i would only be paying one shipping price. Turner motorsport has so many things i wish i could have though! Not engine parts but: Cross brace, Spacer Set for Rear Trailing Arm Bushings, basically renew any bushes that will tighten up the suspension. Once your have your list together, I would check out Turner Motorsports, then email your list to Doug Mahar [[email protected]] get a quote off him as I have found their shipping cost are the cheapest and fast as they use FedX (with no mark up), Pelican use UPS. Quote Share this post Link to post Share on other sites
BMRBOI 8 Report post Posted June 15, 2011 anyone else want to help. I really need to know what rear seals to replace so i can add it to my order... Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted June 16, 2011 I just replaced the crankshaft seal(not sure of correct term) and the pilot bearing at the back Quote Share this post Link to post Share on other sites
BMRBOI 8 Report post Posted June 16, 2011 Sweet, thanks. I just wanted to cover my loose ends before i make my big order lollies. I just replaced the crankshaft seal(not sure of correct term) and the pilot bearing at the back Quote Share this post Link to post Share on other sites
