camera doctor 25 Report post Posted June 15, 2011 (edited) Just installed factory Bluetooth Handfree / Voice control to my Jap Import 2002 E39 530i Touring. Thouight I'd post a few pics and discoveries here, as I know there are others interested in doing this. Firstly, after a couple of months email discussions with www.bimmernav.com, and help from Grant ( Hotwire ) it was decided the best route for a Ex Japan car was to buy the kit that assumes the car has no pre-wiring - even though my car had Japanese phone unit - as none of the Japanese kit is helpful, and is all discarded !! Here is the Japanese Phone Box - Under the black plastic cover on the lefthand side of the wheel well Next step is to remove the Nav Computer and Amplifier from the Lefthand side of the car ( and the CD changer if you have one - mine is removed for DICE unit already ) Behind that is the large opaque white connector that BMW calls X400 Bimmernav supplied a new loom that takes place of the Japanese ( if present ) plug, and has the correct plug on the other end for the ULF module, as the Jap plug, although similar, is wired completely differently. The Bimmernav loom had a 3pin connector for the microphone, but I could not find the compatible plug in the rear of the car, so I traced the Japanese loom and spliced into it for the microphone. As my car has the CD changer removed already, I decided to mount the ULF on the plate the CD changer previously mounted to - I removed the Jap box beside the wheel well, so I could also have put it there I guess, but the position I choose already had a screw for securing it. And a closer View Bluetooth Antenna was screwed under the spare wheel cover. The Bimmernav loom had a pairing button patched onto it, plus they supplied a new centre consule box with a pairing button, which I will trace a couple of wires from the Jap Loom at a later date, but for now I paired my iPhone 4 with the patched button, and hey presto, the address book from my iPhone uploaded to the car .... So, I am stoked ! Sure there are cheaper options out there, but I prefer to have the OEM system, and it works really well, I also updated the microphone to the 2004+ version and it is nice and clear. Voice control took a wee bit to get used to - it did not like my NZ accent for a start, but as most commands have 2 versions of what can be asked, one of them works ! I had previously updated the NAV to MKIV and NZ disc, and the voice control also works some of those functions! You can store phone numbers by voice and recall them later by saying ' Dial Name' and speaking the name !! The steering wheel controls work perfectly, and allow you to scroll thru the address book using the upper display. You can also store and retrieve voice notes to yourself, which I find handy, as I do a lot of my thinking while driving back to the workshop after jobs I am happy to help anybody with any answers I can provide if needed. Edited June 15, 2011 by camera doctor Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted June 15, 2011 I love pictures and big red arrows! nice work. Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted June 15, 2011 Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted June 15, 2011 smart a*se :lollies: Quote Share this post Link to post Share on other sites
isis 16 Report post Posted June 15, 2011 i thought you needed to enable the bluetooth via navcoder or similar? so this is a straight plug and play? Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted June 15, 2011 i thought you needed to enable the bluetooth via navcoder or similar? so this is a straight plug and play? Plug and Play once I traced the mic wires, i.e no coding was necessary. Not sure if that would be the same in a car that previously had no Telephone, can only report what happened in mine Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted June 15, 2011 Wondered when you would post the results of this Greg. Well done - Glad you're happy with it. Tis a brilliant system! That's the third ULF that I have had involvement with & still aint got in my own car Still - with it not being prewired for (to early) I really CBF doing a ground up install - considering I don't often drive the car & my other half doesn't use her cell a lot anyway Quote Share this post Link to post Share on other sites
swauto 4 Report post Posted June 15, 2011 (edited) Plug and Play once I traced the mic wires, i.e no coding was necessary. Not sure if that would be the same in a car that previously had no Telephone, can only report what happened in mine It depends on the VO in each car, since your MK4 ECU was an used ECE spec, so it was probably coded with ECE telephone VO already, so you dont need to do coding again this case:) Otherwise you do have to code it Edited June 15, 2011 by SWAUTOMOTIVE Quote Share this post Link to post Share on other sites
swauto 4 Report post Posted June 15, 2011 Will be better to route the bluetooth antenna to the front, as we have customers that had pairing issue when load more luggage in boot if the bluetooth antenna is installed in boot. Nice job tho Quote Share this post Link to post Share on other sites
Dogballs 124 Report post Posted June 15, 2011 you can use the original jap wiring just change the pins around on the plug, as shown on the attached pdf Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted June 15, 2011 you can use the original jap wiring just change the pins around on the plug, as shown on the attached pdf Yep, that's what I did with the conversion I did a few years back. Compared both systems, picked out the wiring I needed for ULF & relocated into appropriate positions in the plug. Cut the Jap coding tag off & fitted the plug into the ULF module. I think what Greg did was probably simpler though. One thing I haven't bothered to confirm though, the system I changed was in a BM24 equipped car - a car I had just changed radio & nav in. Greg's is a BM54 car - I am not sure if the phone prep wiring is the same in both. Quote Share this post Link to post Share on other sites
Dogballs 124 Report post Posted June 15, 2011 Yep, that's what I did with the conversion I did a few years back. Compared both systems, picked out the wiring I needed for ULF & relocated into appropriate positions in the plug. Cut the Jap coding tag off & fitted the plug into the ULF module. I think what Greg did was probably simpler though. One thing I haven't bothered to confirm though, the system I changed was in a BM24 equipped car - a car I had just changed radio & nav in. Greg's is a BM54 car - I am not sure if the phone prep wiring is the same in both. I'm pretty sure it is, I've done it on my x5 with the BM54.. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted June 15, 2011 Yea, was aware of how Greg was doing his with his BM54 car. The system I did a few yrs back (a Jap to BM24) - they supplied an interface loom incorporating an amplifier with the 54 pin socket & plug each end as they told me that without DSP - the car needed this amp. Apparently, as I understand, in a BM54 equipped vehicle - this amp is not required. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 15, 2011 It depends on the VO in each car, since your MK4 ECU was an used ECE spec, so it was probably coded with ECE telephone VO already, so you dont need to do coding again this case:) Otherwise you do have to code it Not true for the Mk4 and the ULF The coding of the VO is only to tell things like INPA that a ULF should be present, but the VO for ULF has as much impact on the coding of the ULF as the VO for a different colour paint job NavCoder happily codes the ULF to do whatever you want, no mucking about with VO required. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 15, 2011 (edited) Just installed factory Bluetooth Handfree / Voice control to my Jap Import 2002 E39 530i Touring. Thouight I'd post a few pics and discoveries here, as I know there are others interested in doing this. Firstly, after a couple of months email discussions with www.bimmernav.com, and help from Grant ( Hotwire ) it was decided the best route for a Ex Japan car was to buy the kit that assumes the car has no pre-wiring - even though my car had Japanese phone unit - as none of the Japanese kit is helpful, and is all discarded !! Quick note to any Jap BMW owners contemplating this retrofit: The ULF ONLY works with the Euro Mk2, Mk3 or Mk4 nav units. It does NOT work with the Japanese nav unit. Why? Because the jap nav system has a special telephone interface for the jap phone, and it works completely differently to the ULF. The ULF sits on the ibus with all the other ibus devices like the nav system And thus the nav system must expect the ULF to be on the ibus Which the euro nav does and the jap nav doesn't CameraDoctor had already previously replaced his jap nav with the Euro nav, effectively turning the nav system into standard Euro nav system. And thus 100% compatible with the ULF Edited June 15, 2011 by jochen Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 15, 2011 Tip: mount the bluetooth antenna ABOVE the rear parcel tray, under the parcel tray carpet. Much better signal towards the front of the cabin, as the antenna is not enclosed in a steel box (which it is right now!) and the signal is not obstructed anywhere near as much Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted June 15, 2011 Tip: mount the bluetooth antenna ABOVE the rear parcel tray, under the parcel tray carpet. Much better signal towards the front of the cabin, as the antenna is not enclosed in a steel box (which it is right now!) and the signal is not obstructed anywhere near as much Cheers Jochen, My car is a touring, so it is mounted under the wooden floor, not steel. No issues so far, but poster SWAutomotive suggested I may have issues if luggage was above it, so I may look at running it up to the centre consule as per the bimmernav website, would need to get a longer cable I think - any idea where I could get that ?? Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 15, 2011 Cheers Jochen, My car is a touring, so it is mounted under the wooden floor, not steel. No issues so far, but poster SWAutomotive suggested I may have issues if luggage was above it, so I may look at running it up to the centre consule as per the bimmernav website, would need to get a longer cable I think - any idea where I could get that ?? Put it in the C pillar, midway up as high as the cable reaches. Better, less obstructed view of the vehicle interior Otherwise, if you want to go to the C pillar, you'll need a 50 ohm SMB extension cable.... Quote Share this post Link to post Share on other sites
swauto 4 Report post Posted June 24, 2011 Not true for the Mk4 and the ULF The coding of the VO is only to tell things like INPA that a ULF should be present, but the VO for ULF has as much impact on the coding of the ULF as the VO for a different colour paint job NavCoder happily codes the ULF to do whatever you want, no mucking about with VO required. Not talking about the coding for ULF, I was thinking that if ULF VO is not in the car then the MK4 probably does not know ULF is in the car. I mean MK4 provides UI so, without coding MK4 with ULF VO, it may not show telephone option on screen. So you can code MK4 without adding VO in car but everthing will revert back to default coding acording to car VO if dealer code it again. So to get 100% retrofit, just need to add VO in and code whole car with new VO list. so it will not going to change again Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 24, 2011 Not talking about the coding for ULF, I was thinking that if ULF VO is not in the car then the MK4 probably does not know ULF is in the car. I mean MK4 provides UI so, without coding MK4 with ULF VO, it may not show telephone option on screen. Nope, the Mk4 automatically sees the ULF as soon as the ULF is connected to the databus. The Mk4 needs no coding to detect if the ULF is present or not. Not only does it not need coding, there is no coding foreseen. Nothing to change. Plug and play. So you can code MK4 without adding VO in car but everthing will revert back to default coding acording to car VO if dealer code it again. Well, dealer struggles anyway with the unforseen combination of Japanese Market car fitted with Mk4 nav computer :-) Quote Share this post Link to post Share on other sites
Ozmatey 0 Report post Posted February 11, 2012 Thanks for such a comprehensive thread on this topic. I completely pulled apart the rear of my 1998 E39 528iT - both to learn where all the modules are located and to install an OEM ULF. HOWEVER..... My car has a DSP, Mk IV Sat Nav, Loewe TV receiver in it along with the Built in Motorola GSM phone in the centre console. I could not for the life of me find a 54 pin connector or ariel connector ANYWHERE. I'm guessing that since the car was prewired for the built in GSM phone, they didn't also provide the wiring for the ULF. Does that sound right? Is there any way to have BOTH the phone and ULF in at the same time? I would be even prepared to remove the phone all together if I could get my ULF to work. Thanks in advance for any help you can give me. Glenn Melbourne AU Quote Share this post Link to post Share on other sites
Dogballs 124 Report post Posted February 12, 2012 Thanks for such a comprehensive thread on this topic. I completely pulled apart the rear of my 1998 E39 528iT - both to learn where all the modules are located and to install an OEM ULF. HOWEVER..... My car has a DSP, Mk IV Sat Nav, Loewe TV receiver in it along with the Built in Motorola GSM phone in the centre console. I could not for the life of me find a 54 pin connector or ariel connector ANYWHERE. I'm guessing that since the car was prewired for the built in GSM phone, they didn't also provide the wiring for the ULF. Does that sound right? Is there any way to have BOTH the phone and ULF in at the same time? I would be even prepared to remove the phone all together if I could get my ULF to work. Thanks in advance for any help you can give me. Glenn Melbourne AU Hi Glenn, I suspect you have a 'SA629' phone..?? http://www.realoem.com/bmw/partgrp.do?mode...hg=84&fg=10 it is possible to get your ULF working but it isnt a simple plug and play.. you will need to modify the loom to suit.. have you got a bluetooth antenna for your ULF? ( and coax cable?) D Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted February 12, 2012 I could not for the life of me find a 54 pin connector or ariel connector ANYWHERE. I'm guessing that since the car was prewired for the built in GSM phone, they didn't also provide the wiring for the ULF. Does that sound right? Is there any way to have BOTH the phone and ULF in at the same time? I would be even prepared to remove the phone all together if I could get my ULF to work. The ULF is a phone The Motorola phone is a phone You can have one or the other, not both. Only one phone can exist in the vehicle. The phone transceiver is in the trunk/boot space, close to the nav. Easy to recognise. Post a photo and we can identify the modules for you Quote Share this post Link to post Share on other sites
Japan1 0 Report post Posted May 28, 2015 Camera doctor, I am in Japan would like to do this conversion. Do you know the part number for the loom. I have everything else. Quote Share this post Link to post Share on other sites
TAJ 0 Report post Posted September 11, 2018 Hi Guys, i am new to the forum. I see the last post was in 2015. I am guessing that some might not even be driving an E39 anymore. I was just wondering if there is anybody who can help me do the conversion in my 2002 Japenies imported wagon? Thanks TJ Quote Share this post Link to post Share on other sites
