cytamen 1 Report post Posted June 24, 2011 Hey guys, Has anybody been through the process of having their trans rebuilt? I have some pretty annoying issues with 3rd to 2nd transfer in my transmission as well as an oil leak, and wondering if anybody can recommend a good shop to do transmission repairs and if you have any ballpark idea of what cost I should be looking at, that'd be great. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted June 24, 2011 try kayne barrie motorsport . or just swap it for another box Quote Share this post Link to post Share on other sites
cytamen 1 Report post Posted June 24, 2011 I wanted to rebuilt cause the amount of labour involved in swapping a box & the cost of the box itself is quite high, and knowing my luck after a month the box will stuff up. It's a manual coversion car. Quote Share this post Link to post Share on other sites
cytamen 1 Report post Posted June 30, 2011 Alright, so I've found by checking the number printed on the box that the person who converted this car to manual decided to use a Getrag 225. I won't be rebuilding this and I'm either going to be an idiot and spend $3800 on a brand new unused Getrag 250, or buy a ZF 320Z box. I just need to know if there will be any other parts needed to get this box to fit, or if it should just bolt straight up? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted June 30, 2011 (edited) Alright, so I've found by checking the number printed on the box that the person who converted this car to manual decided to use a Getrag 225. I won't be rebuilding this and I'm either going to be an idiot and spend $3800 on a brand new unused Getrag 250, or buy a ZF 320Z box. I just need to know if there will be any other parts needed to get this box to fit, or if it should just bolt straight up?you will need a matching driveshaft and maybe mount etcwhat is that gearbox from a e30 m20 ??? dont know that number. where did you get that number from. what abou the diff ratio you have??? how many rpm at 100kmh in 5th is it doing . just buy a good used getrag 220 from a 316i 318ti 318is 318i 320i 323i 325i or zf from a 328i or m3. i can help there if you need. 021433600 neither give much trouble , most will see 400,000km if oil is changed and idiots dont change gears with no clutch etc Edited June 30, 2011 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
cytamen 1 Report post Posted July 2, 2011 you will need a matching driveshaft and maybe mount etc what is that gearbox from a e30 m20 ??? dont know that number. where did you get that number from. what abou the diff ratio you have??? how many rpm at 100kmh in 5th is it doing . just buy a good used getrag 220 from a 316i 318ti 318is 318i 320i 323i 325i or zf from a 328i or m3. i can help there if you need. 021433600 neither give much trouble , most will see 400,000km if oil is changed and idiots dont change gears with no clutch etc The number printed on the transmission in my car is: 220.0.0225.94 which searches tell me Getrag 225 Theres one on trademe at the moment which has the number 220.0.0225.97 which is a Getrag 250. If I buy the 250, what other parts would I need for it to fit? And does anybody have a 225? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted July 2, 2011 (edited) The number printed on the transmission in my car is: 220.0.0225.94 which searches tell me Getrag 225 Theres one on trademe at the moment which has the number 220.0.0225.97 which is a Getrag 250. If I buy the 250, what other parts would I need for it to fit? And does anybody have a 225? if its a getrag from a e36 or e46 318i 316i 320i 323i 325i 318ti 318is it will work fine .they all are the same , just bmw keep changing part numbers etc Edited July 2, 2011 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
cytamen 1 Report post Posted July 20, 2011 (edited) So, I now have a Getrag 250 gearbox. A brand new Luk flywheel. A brand new Sachs Clutch Kit. A brand new clutch slave. And I've also had to order a new starter motor, a selector rod and a shifter arm. I've got all of these except the shifter arm Part number is 25 11 1 221 541 and found in 320i 325i (M50) & 320i (M52) 323i (M52) I have one from 2.8L and it's not the right size so must be from one of the above. Does anybody have one lying round? Edited July 20, 2011 by cytamen Quote Share this post Link to post Share on other sites
