Gus 5 Report post Posted May 21, 2005 well i have inherited a wooden steering wheel...... hahaha anyway i want to get rid of all the varnish, and make it a nice matt finish.....will just sanding work, or do i need a special type of finish to make this happen? so pimp Quote Share this post Link to post Share on other sites
318is 0 Report post Posted May 21, 2005 if your painting it, use a resene product called "smooth surface sealer" that will seal the varnish or what ever is on the wood. Then paint away with your choiceof colour...SPRAY of course..... Quote Share this post Link to post Share on other sites
bmwsparkle 3 Report post Posted May 21, 2005 ur so not getting rid of the wooden look are you? if you are ill buy it, wooden wheels pwn so hard Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted May 21, 2005 The way I read it, Gus wants a wooden wheel, but just not a gloss finish - presumably for better grip on the wheel. There is such a thing as satin varnish which is the least glossy - I wouldn't leave the wood bare - it would attratc dirt and you would have to sand it everytime you wanted to clean it - satin varnish is you best option, although that will develop a shine as your hands polish it. Quote Share this post Link to post Share on other sites
bimmer boy 21 Report post Posted May 21, 2005 proberbly best to sand it off then put like a satin finish on it or a kind of wax so it wont get stained , was in a aston today and it had like a matt wood finish looked very nice Quote Share this post Link to post Share on other sites
MattA 165 Report post Posted May 22, 2005 (edited) Your correct Gus.. sand paper and lots of time start with an 80 grit paper to get the varnish off.. then higher grades to finish off. You could use a stripper but check it on the steel part to make sure there's no reaction (from my experience Coopers is by far the best) You can get all sorts of varnish satin or mat finish I'd advise using an exterior or marine varnish as interior stuff tends to yellow and craze in the sun. maybe talk to a car restorer cheers Matt edit: DON"T use any sort of power tool it will melt the varnish then it just soaks into the wood making for more sanding. Edited May 22, 2005 by MattA Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted May 22, 2005 brilliant....sounds like fun if i ever get a boss kit for it, ill be pimping Quote Share this post Link to post Share on other sites
downlow 0 Report post Posted May 23, 2005 Carls gota a boskit forsale i think, hava look in the forsale section. Quote Share this post Link to post Share on other sites
