BlowMyWhistle
Pulse Generator?
Hi Y'all. my baby's car, e30 320i m20 10/93
She got some new leads thru her work (SCA) good Bosch leads etc. But no pulse generator!
So what's my options? Pull a cap off and slip the old one back over the new lead?
Bit reluctant to destroy brand new lead!
Gunner have a look at it tomorrow!
I know Y'all are sitting inside tonight on account NZ is land of great white cloud!
Cheers!
tomorrow: It doesn't have one! Apparently if they run without it they are okay without it?
Cheers!
nah, on closer inspection it does have one on No 6, it was right at the front of the leads bundle.
Gunner send them back., they super leads ann 7mm thick, need 5mm leads wirth the pulse generator.
It doesn't even need them, they been tested and come back as good.
Will run fine without it.
For future reference the car runs fine without the cylinder reference lead.
Put new leads on it, It does run okay without the 'pulse generator'.
I disconnected the lead from the end where it plugs under the plug in socket and it doesn't run without it!
Meanwhile I have a spare lead floating around the engine bay...
Naturally I'd like to simply unplug this, rather than hack at it with sidecutters!
So what do I do?
Should run with out it... There is two plugs there, one is for the crank position sensor, you may have unplugged that (which it wont run without)
