Michael. 2313 Report post Posted August 19, 2011 (edited) I'm after some custom nolathane / polyurethane spacers, but they will need to be machined up to the size. Anyone deal with that themselves or know of a place in Auckland I can try? After four spacer disks, 50mm diameter x 4mm thick x 17.5 center bore. Any help would be great! Edited August 19, 2011 by E36V8 Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted August 19, 2011 Autoline can make you up some in two part urethane. Well they could last time i checked. Otherwise you could diy it. http://www.topmark.co.nz/articlelive/artic...-Urethanes.html 750grams was about $80 for the f82 last i checked. You might want to go for something a little harder depending on what it is for. Otherwise you can get urethane rod from a few places. Do they need to be made in urethane? Would it work in delrin? What sort of tolerance is needed? Quote Share this post Link to post Share on other sites
