justin_cosgrove 4 Report post Posted August 22, 2011 As the title suggests, how do I check the diff oil level? and do I have to have the motor at operating temp to check the automatic trans oil? or can it be cold? Sorry I know it's a noob question but I'm new to BMWs Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted August 22, 2011 On the back of the diff there is two 17mm inverse hex bolts, the bottom is drain and top is fill. As rude asit sounds, the correct procedue is to fill till it come backs out the top hole to see if it's full. Same for the transmission if manual and, if your auto doesn't have a dipstick in the engine bay then that too. Quote Share this post Link to post Share on other sites
justin_cosgrove 4 Report post Posted August 22, 2011 On the back of the diff there is two 17mm inverse hex bolts, the bottom is drain and top is fill. As rude asit sounds, the correct procedue is to fill till it come backs out the top hole to see if it's full. Same for the transmission if manual and, if your auto doesn't have a dipstick in the engine bay then that too. Ahh, that's how I filled the manual trans on my galant when I did the manual conversion, I filled it till it overflowed, is there a way of just checking if the diff oil level is still where it's meant to be? My auto does have a dip stick in the engine bay, does the engine need to be hot to check the auto trans oil? or is cold ok too? Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted August 22, 2011 nope the procedure i said is the way. you could put a clean finger in the hole and check for fluid (keep your mind out the gutter ) From memory you should do it when its warm, but i change cars so often its been a few years since ive filled an auto so dont quote me, someone else will chime in, or you could run a google search Quote Share this post Link to post Share on other sites
