dereklau007 1 Report post Posted August 28, 2011 So I've done the time consuming part of installing the reverse camera and now up to the wiring part. I've only got one question, I've been trying to look for a 12v wire which I can tap into for powering the reverse camera but I'm lost to find one. I've read on other DIY's that people have tapped into a violet/white wire which is 12v (ACC or switched I'm not sure). This is for a 2002 530i Motorsport Thanks in advance, Kind regards, Derek Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted August 28, 2011 Just tap into the reverse light. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted August 28, 2011 So I've done the time consuming part of installing the reverse camera and now up to the wiring part. I've only got one question, I've been trying to look for a 12v wire which I can tap into for powering the reverse camera but I'm lost to find one. I've read on other DIY's that people have tapped into a violet/white wire which is 12v (ACC or switched I'm not sure). This is for a 2002 530i Motorsport Thanks in advance, Kind regards, Derek Yes violet/white for acc, check it though - there is another wire same colour in the loom that is not Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted August 29, 2011 Yes violet/white for acc, check it though - there is another wire same colour in the loom that is notIf you have long enough wire then splice into reverse wire or just use 12v socket with a switch. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted August 29, 2011 If you have long enough wire then splice into reverse wire or just use 12v socket with a switch. Access to reverse & acc inputs are side by side in the loom in the boot. The camera can be powered continuously (ign switched of course) & is better this way so as to avoid any delay in power up when selecting reverse Quote Share this post Link to post Share on other sites
dereklau007 1 Report post Posted August 29, 2011 (edited) Thanks for all the help. Initially I was considering tapping into the reverse light however as Grant has pointed out that if 12v acc is used then there is no delay in powering up. I'm still using the reverse light wire to trigger the relay so that once reverse gear is engaged it will connect pin17 to ground and the screen will automatically switch to the reverse camera input. Just one further question. I have a 5 pin relay and am slightly confused with using 87a or 87 as the pin 17 connection. Does it even matter? Thanks again, Derek Edited August 29, 2011 by Derek007 Quote Share this post Link to post Share on other sites
kwhelan 242 Report post Posted August 29, 2011 Thanks for all the help. Initially I was considering tapping into the reverse light however as Grant has pointed out that if 12v acc is used then there is no delay in powering up. I'm still using the reverse light wire to trigger the relay so that once reverse gear is engaged it will connect pin17 to ground and the screen will automatically switch to the reverse camera input. Just one further question. I have a 5 pin relay and am slightly confused with using 87a or 87 as the pin 17 connection. Does it even matter? Thanks again, Derek http://www.teamrocs.com/technical/pages/relay_basics.htm Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted August 30, 2011 Thanks for all the help. Initially I was considering tapping into the reverse light however as Grant has pointed out that if 12v acc is used then there is no delay in powering up. I'm still using the reverse light wire to trigger the relay so that once reverse gear is engaged it will connect pin17 to ground and the screen will automatically switch to the reverse camera input. Just one further question. I have a 5 pin relay and am slightly confused with using 87a or 87 as the pin 17 connection. Does it even matter? Thanks again, Derek Use 87, 87a is normally closed contact Quote Share this post Link to post Share on other sites
dereklau007 1 Report post Posted August 30, 2011 For all the help I have successfully installed my reverse camera and working perfectly! Take a little getting used to but it's a great feature. At first I thought I had bitten off more than I can chew. Great satisfaction when a project comes out great Quote Share this post Link to post Share on other sites
