sam726 29 Report post Posted September 7, 2011 How are these readings for compression on a 1990 535is e34 1: 180 2: 165 3: 170 4: 170 5: 170 6: 175 Thanks for the help, im a bit of a noob when it comes to understanding compression readings. Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted September 7, 2011 not to bad , 180 is good 165 is getting down , but to be expected for one of these. if down near 140 i would be looking at pulling the head off etc. used to get upwards of 200 for a older e28 535i with higher compression pistons. give it a good hot thrash and see if it comes up any Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 7, 2011 Always crack the spark plugs to release any carbon from around the plug, run the engine, remove all the plugs and do the compression test with wide open throttle. Quote Share this post Link to post Share on other sites
