sik bm 0 Report post Posted September 22, 2011 hey all have just brought a e30 320i auto. when u put it in any gear it doesnt move even reverse. thinking its the selector but not sure. any advice appreciated. cheers garry Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2143 Report post Posted September 22, 2011 car you push the car forward in park? neutral? is there the same resistance? selector cable may be damaged. If it moves in nuetral when pushed but not park then the cable will be fine. I would then look at the fluid level Quote Share this post Link to post Share on other sites
sik bm 0 Report post Posted September 22, 2011 _Ethrty-Andy_ said: car you push the car forward in park? neutral? is there the same resistance? selector cable may be damaged. If it moves in nuetral when pushed but not park then the cable will be fine. I would then look at the fluid level it moves in neautral but not park. and fluid level is fine. i dont know what else it could possibly be except for a wiring problem maybe?? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 22, 2011 sdways..E30 said: it moves in neautral but not park. and fluid level is fine. i dont know what else it could possibly be except for a wiring problem maybe?? Broken oil pump drive in the front of the box Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2143 Report post Posted September 22, 2011 isnt usually any wiring unless its the sport box with S E and Snow. yep as glenn said, thats about the only realistic thing left Quote Share this post Link to post Share on other sites
sik bm 0 Report post Posted September 22, 2011 alright where abouts exactly is the oil pump drive located? Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2143 Report post Posted September 22, 2011 iirc its the input on the gearbox, but if it does out to be that is probably not worth fixing and just getting a new gearbox. Quote Share this post Link to post Share on other sites
Dr. M 10 Report post Posted September 22, 2011 Problem solved! Quote Share this post Link to post Share on other sites
KRZY-E30 0 Report post Posted September 22, 2011 My auto box did the same, but it works fine in Reverse. So I'm buy a Full Manual conversion Kit From Jono51 Quote Share this post Link to post Share on other sites
Jono51 59 Report post Posted September 22, 2011 the main problems with these boxes is lack of service, in response to original post the best you can do for yourself is remove the pan, replace the filter and have a fluid flush done, it might only be a blocked filter, any other advice will be to complex cheers Jon Quote Share this post Link to post Share on other sites
Jono51 59 Report post Posted September 22, 2011 E30BM325i said: My auto box did the same, but it works fine in Reverse. So I'm buy a Full Manual conversion Kit From Jono51 Hi Mike, yours appears to be a different fault, common of the 4hp22 one thing that can cause this is a good bootful on the accelerator whilst in neutral or park, repairable, but labour, parts etc and not as satisfying as a manual conversion hear from you soon Quote Share this post Link to post Share on other sites
KRZY-E30 0 Report post Posted September 22, 2011 Jono51 said: Hi Mike, yours appears to be a different fault, common of the 4hp22 one thing that can cause this is a good bootful on the accelerator whilst in neutral or park, repairable, but labour, parts etc and not as satisfying as a manual conversion hear from you soon Ah Thanks for that info! Now I know who was at fault lol. My Ex-partner and I were arguing about something, then she put the gear into Park while I was doing about 60km. Not so good. I just sent you and email Jon. Quote Share this post Link to post Share on other sites
Jono51 59 Report post Posted September 22, 2011 E30BM325i said: Ah Thanks for that info! Now I know who was at fault lol. My Ex-partner and I were arguing about something, then she put the gear into Park while I was doing about 60km. Not so good. I just sent you and email Jon. OMG! but the noise Priceless !!! will check my emails, Quote Share this post Link to post Share on other sites
