AzonicNick 0 Report post Posted September 30, 2011 Hi all, A issue with the indicator, which was a intermittent niggle seems to be becoming more and more common. It either works perfectly or the following.. Just on the right side, the left works perfectly, the indicator light in the dash clicks at about double rate but none of the actual indicators do. Im no pro when it comes to electronics so am not sure where to start other than the bulbs Cheers! Nick Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted September 30, 2011 Double rate of clicking generally means a bulb has blown. If it only does it sometimes then it maybe a bulb that isn't seated correctly or a wiring issue. I'd check that no bulbs are blown first. If no luck there then try lightly sanding and cleaning all the bulb contacts with a little CRC. Check the condition of the wiring harnesses while you're at it. Oh, and also that the fuses that deal with the indicators are seated correctly in their slots. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted September 30, 2011 i second that . most likly corrsion and bad spring terminals where the bulbs plug in . or just intermitant bulbs(on there way out) Quote Share this post Link to post Share on other sites
AzonicNick 0 Report post Posted October 1, 2011 Cheers guys all sorted, new bulbs all round and still giving issues so a bit of a clean did the trick! Quote Share this post Link to post Share on other sites
