Dogballs 123 Report post Posted October 3, 2011 (edited) for sale: retrofit loom for e46/2/3/4/5 already has flat 7pin plug fitted.. it has a few terminals cut off but can replace if required... can supply fitting instructions if required also. $75 will put on trademe soon if no takers here.. Edited October 3, 2011 by Dogballs Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3034 Report post Posted October 3, 2011 Is this for the pre-facelift E46, or the facelifted version, as the lighting wiring is different? Also, where does the connector plug into, so I can check i have the right plug in the right place to accept it? Quote Share this post Link to post Share on other sites
Dogballs 123 Report post Posted October 4, 2011 Is this for the pre-facelift E46, or the facelifted version, as the lighting wiring is different? Also, where does the connector plug into, so I can check i have the right plug in the right place to accept it? Hi, this is off a facelift e46, it connects via a number of places, not just one - from the front end of the car to the rear of course... mainly the main distribution box, light switch, rear lights.. hope this helps, just ask if you need more info/details Quote Share this post Link to post Share on other sites
