sam726 29 Report post Posted November 15, 2011 Hi there, My 535is E34 has dropped a valve it seems and could possibly have incurred more damage as a result and im wanting to know peoples opinions on what would be my best option to fix and stop more problems occuring as its getting into high kms now. Im wondering whether anyone knows what options i would be able to pursue in rebuilding it with getting it all rebored and machined aswell as changing all the gaskets etc... or if anybody can point me towards a reputable person/business to get a quote for this. Otherwise whether anyone knows of a good low kms condition engine i could swap in without many issues. Not sure if Hartge Brent may know of anyone to go to. Thanks, Sam Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted November 15, 2011 (edited) if its dropped a valve there will most likly be holes in teh pistons and massive damage to the cylinder head. i would say time for a engine swap. the reason they normally drop a valve is due to wear in the camshaft lobes which causes the valve to shut very quickly then eventually breaking the head off the valve steem. cam wear is normally caused by lack of oiling to the camshaft due the banjo(hollow bolts) coming undone. you engine might look like this inside Edited November 15, 2011 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
polley 916 Report post Posted November 15, 2011 I have a M30b35 for sale with approx 190,000KM's on it. Quote Share this post Link to post Share on other sites
sam726 29 Report post Posted December 1, 2011 So here's the diagnosis, "I got your BMW apart yesterday. The engine had broken 2 rockers & worn the cam shaft badly. However, the good news is the basic lower engine assembly is OK. So below is the parts I need to fix the head & a couple of options. Parts: 1/ 12x rockers $330 2/ Head Gasket Set (complete) $470 3/ 1x injector ?? 4/ Distributor Rotor ?? Machining: 1/ Cut valves & seats $110 2/ surface head $100 3/ repair cam shaft $300" Whats everyones opinions in terms of whether its worth getting it repaired this way or whether i should look at a 2nd hand engine etc...? Thanks Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted December 1, 2011 (edited) So here's the diagnosis, "I got your BMW apart yesterday. The engine had broken 2 rockers & worn the cam shaft badly. However, the good news is the basic lower engine assembly is OK. So below is the parts I need to fix the head & a couple of options. Parts: 1/ 12x rockers $330 2/ Head Gasket Set (complete) $470 3/ 1x injector ?? 4/ Distributor Rotor ?? Machining: 1/ Cut valves & seats $110 2/ surface head $100 3/ repair cam shaft $300" Whats everyones opinions in terms of whether its worth getting it repaired this way or whether i should look at a 2nd hand engine etc...? Thanks i have a 180k e34 engine in the shed. its a bare engine,but youve got all the bits anyway. $600 cheers marty Edited December 1, 2011 by BM Weapon Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 1, 2011 here is how i look at it...if you fix yours you know exactly what you have got....any second hand engine is partly unknown.Any M30 engine will eventually blow the head gasket becuase of diff movement between the iron block and alloy head.Even the most religiously maintained cars will blow the head gasket.If you do yours now with gaskets and new bolts it will be done and known.Even the newest M30 does have a dizzy and rotor. Quote Share this post Link to post Share on other sites
