Kaz 64 Report post Posted November 16, 2011 Hi, I've done a quick search online and can't find anything specific to my problem. Basically, as soon as I turn the key, the speedo shoots up to 240KM/H and stays there, and the odometer doesn't change when I drive. The petrol gauge, rev counter, temperature gauge, and the L/km gauge still work as normal. This happened after I got a flat battery today. Any ideas on how I could fix this? The fuses all seem to be fine. Thanks for any help. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted November 16, 2011 it will either be the sensor plug on the diff or there is a fault along those wires leading to it that is grounding out the wire Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted November 16, 2011 have you tried hitting or tapping it? might be a connection problem or something is stuck in there Quote Share this post Link to post Share on other sites
