samo455 7 Report post Posted November 22, 2011 hay i just scored a e36 325 coupe engine says hartge 2.8 and it has full hartge exhaust rear badge momo millennium witch all hartge in the uk seam to have the car is nz new has all this stuff been installed by some one here or did it come like this are there any markings on the engine to identify if it is hartge or if it is even a 2.8 could just be m50 with hartage engine cover i gess but studying bmw forums in the uk some say thay used m50b25 to buld the hartge 2.8 any way but i dont see y any one no the truth behind this Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted November 22, 2011 (edited) http://www.bimmersport.co.nz/forums/index....t=0&start=0 I'd say the quickest way to find out if it is a 2.8 would be to pull a spark plug and put a rod down it and measure the stroke from it. 84mm will mean 2.8 Edited November 22, 2011 by bbs Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted November 22, 2011 what he said ^. also take it gavin at hi-velocity and run it on his dyno , my 325i did 112kw same as my 328i , so if its more than maybe its a hartge , but i would guess its just an hartge engine cover brought on ebay etc. but remove the covers and see if there are any hartge stamps /markings on the head etc (inlet side) Quote Share this post Link to post Share on other sites
samo455 7 Report post Posted November 22, 2011 thanks guys ill cheek the strok today Quote Share this post Link to post Share on other sites
samo455 7 Report post Posted November 24, 2011 yep 2.5 Quote Share this post Link to post Share on other sites
samo455 7 Report post Posted January 9, 2012 (edited) ok i said yep 2.5 because i found some numbers on the engine that said 25 in the same place my bros 528 says 28 but measured the stoke today and it is 84mm so she 2.8 hartge must of just stoked them im stoked sc14 here i come Edited January 9, 2012 by samo455 Quote Share this post Link to post Share on other sites
