Top Secret 2 Report post Posted November 25, 2011 Hey guys, My e30 has an idling problem when it is cold, and it gets worse when you put the headlights on. The revs will fluctuate, and it will die sometimes. When the car is warm, it is perfect. It has been given a full service, and the airflow meter has been cleaned. Any help would be appreciated. Cheers Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 25, 2011 take idle control off and clean also. big failure with them Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted November 25, 2011 also check for any vac air leaks around all the intake system , hoses split , cracks in intake boot etc etc Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted November 25, 2011 check your throttle position sensor and connections, maybe a upper intake manifold clean when you remove the top half and clean the throttle body Quote Share this post Link to post Share on other sites
