Mark 178 Report post Posted December 20, 2011 (edited) RE: Temp gauge, fuel gauge and odometer not working in E34 535i cluster. Am I correct in saying that if I swap another cluster into the car but retain the original coding plug then I will still have the original odometer readings etc? If this is the case then that would be a much easier option than changing the capacitors which seems to be the common way to cure this problem. Thoughts from the experts? Edited December 20, 2011 by _Mark_ Quote Share this post Link to post Share on other sites
BM WORLD 1299 Report post Posted December 20, 2011 what year is your 535i , as there are 2 types , early one you can swap the millage plug over , later type millage stays in the cluster Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted December 20, 2011 Thanks Brent, car is a 1990 Quote Share this post Link to post Share on other sites
BM WORLD 1299 Report post Posted December 20, 2011 Thanks Brent, car is a 1990ok that should have the later type clusterwhats the millage of it ?? Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted December 20, 2011 Mileage is 122,xxx Quote Share this post Link to post Share on other sites
BM WORLD 1299 Report post Posted December 20, 2011 (edited) Mileage is 122,xxxhhhmmmmight be hard to find one with low k's like that one are you sure its a cluster problem?? maybe just test with another one. or use parts from another one to fix yours etc Edited December 20, 2011 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
