rusdvl 0 Report post Posted January 10, 2012 Hi guys, Wanting to replace the air filter on my E39 540i... any suggestions of good filters? Or will just any aftermarket filter will do? Thanks Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted January 11, 2012 The genuine factory filter is fine in the long run, most of those 'performance' filters are just a rip off and all they do is allow more dirt to pass through and dirty your oil. Quote Share this post Link to post Share on other sites
Guest 4167 Report post Posted January 12, 2012 I use K&N filter for my 540i .and feeling a bit smooth than paper filter. Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted January 12, 2012 +1 for genuine BMW filter. or K&N panel replacement only if you will wash and re-oil them carefully as needed. Quote Share this post Link to post Share on other sites
rusdvl 0 Report post Posted January 12, 2012 +1 for genuine BMW filter. or K&N panel replacement only if you will wash and re-oil them carefully as needed. How often are you supposed to wash/oil them? Quote Share this post Link to post Share on other sites
twisted 45 Report post Posted January 13, 2012 (edited) +1 for genuine. If you do go aftermarket, go panel filter only. The 540 already has a very good cold air setup, and moving to a pod style only hurts economy and power. Though the v8 induction sound is great with a pod. Wash/oil K&N when its visibly dirty? Not sure. Oil based filters can coat your MAF/Airflow meter with oil which can cause issues that CRC MAF cleaner may, or may not be able to solve. Edited January 13, 2012 by -Alias- Quote Share this post Link to post Share on other sites
rusdvl 0 Report post Posted January 13, 2012 +1 for genuine. If you do go aftermarket, go panel filter only. The 540 already has a very good cold air setup, and moving to a pod style only hurts economy and power. Though the v8 induction sound is great with a pod. Wash/oil K&N when its visibly dirty? Not sure. Oil based filters can coat your MAF/Airflow meter with oil which can cause issues that CRC MAF cleaner may, or may not be able to solve. Ok... I guess I'll just stick with the original one... Thanks guys. Quote Share this post Link to post Share on other sites
shaneg 0 Report post Posted January 13, 2012 As i read somewhere.. "Why put usa made stuff in a German car?" Quote Share this post Link to post Share on other sites
NZ BMW 368 Report post Posted January 13, 2012 This is a good saying: "If you love sand - K&N is your brand" Properly oiled and cleaned I don't think they're that bad for your car but you won't get any performance gains to write home about. Just make sure your car is serviced properly and you replace filters and ignition items when they need it rather than "performance" air filters. Quote Share this post Link to post Share on other sites
