Apex Effects 3 Report post Posted January 21, 2012 Hey people had a me a big old internet's search for this following question but so far nothing. any links or information would be a great help. I'm after the physical dimensions of a m50/m52 long block set up. Like how long how wide an possibly if anyone's got a getrag or zf box for one floating around on the floor, Could measure the length of that to it be a great help? Cheers Shaun Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted January 21, 2012 Ive got an m50 and a manual box in the garage I can measure Do you want dimensions with or without manifolds Quote Share this post Link to post Share on other sites
Apex Effects 3 Report post Posted January 21, 2012 (edited) With intake on please an the width of the head(just the top of rocker cover will do) an the length of head/block an length of gearbox. Thanks Edited January 21, 2012 by GASTKR Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted January 22, 2012 (edited) getrag 250 box length is about 500mm m50/52 head is 660mm long not including front cover. Vanos front cover is maybe another 50mm width of engine with intake is about 550mm Edited January 22, 2012 by bbs Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted January 22, 2012 (edited) like he said^ long block length 670mm + 90mm for fan and water pump assy width 265mm without intake (couldnt find intake mani sorry) getrag case 500mm + 60mm to end of output shaft Edited January 22, 2012 by Ben Quote Share this post Link to post Share on other sites
Apex Effects 3 Report post Posted January 22, 2012 cheers fellas. So if it was a non vanos setup an wasn't running a clutch fan. id be looking at? 700mm? Another quick question how long is the shift linkage off the back of the gearbox when mounted? Quote Share this post Link to post Share on other sites
