Apex Effects
M52's full specs
Hey people
had a me a big old internet's search for this following question but so far nothing. any links or information would be a great help.
I'm after the physical dimensions of a m50/m52 long block set up. Like how long how wide an possibly if anyone's got a getrag or zf box for one floating around on the floor, Could measure the length of that to it be a great help?
Shaun
Ive got an m50 and a manual box in the garage I can measure
Do you want dimensions with or without manifolds
With intake on please an the width of the head(just the top of rocker cover will do) an the length of head/block an length of gearbox. Thanks
Edited by GASTKR
getrag 250 box length is about 500mm
m50/52 head is 660mm long not including front cover. Vanos front cover is maybe another 50mm
width of engine with intake is about 550mm
Edited by bbs
like he said^
long block length 670mm + 90mm for fan and water pump assy
width 265mm without intake (couldnt find intake mani sorry)
getrag case 500mm + 60mm to end of output shaft
Edited by Ben
cheers fellas. So if it was a non vanos setup an wasn't running a clutch fan. id be looking at? 700mm?
Another quick question how long is the shift linkage off the back of the gearbox when mounted?
