khello 0 Report post Posted January 27, 2012 hi guys, im new to the forum. i joined as i am in the market for a e60 545i. and what better place to get advice from a bmw forum!! i just wanted some help first of all in finding a decent one and also to get advice on what i should be looking for when i go to inspect etc also what i should be expecting to pay. i would really preffer a black one. Any help would be much appreciated guys. cheers Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted January 27, 2012 (edited) hi guys, im new to the forum. i joined as i am in the market for a e60 545i. and what better place to get advice from a bmw forum!! i just wanted some help first of all in finding a decent one and also to get advice on what i should be looking for when i go to inspect etc also what i should be expecting to pay. i would really preffer a black one. Any help would be much appreciated guys. cheers i think jgbmw in welly have a really nice white one edit maybe they dont..it doesnt show up on teh web.... Edited January 28, 2012 by kiwi535 Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted January 28, 2012 i think jgbmw in welly have a really nice white one edit maybe they dont..it doesnt show up on teh web.... although this is interesting! Quote Share this post Link to post Share on other sites
khello 0 Report post Posted January 28, 2012 although this is interesting! yea that one is NICE!! but unfortunately a little bit out of my budget. I seem to look at these two alot on trademe http://www.trademe.co.nz/motors/used-cars/...n-420508708.htm and http://www.trademe.co.nz/motors/used-cars/...n-394178162.htm Any thoughts one these? from what iv read people do seem to lean towards the 2005 alot more? Quote Share this post Link to post Share on other sites
khello 0 Report post Posted January 28, 2012 mmmm nice aswell http://www.trademe.co.nz/motors/used-cars/...n-394178162.htm Quote Share this post Link to post Share on other sites
shaneg 0 Report post Posted January 28, 2012 ^all straight from Japan.. Not sure on the differences between nz new and Japan e60 however. There are a few differences in other models. Quote Share this post Link to post Share on other sites
khello 0 Report post Posted January 28, 2012 i take it that ex japan ones arent as good as nz new then..?? Quote Share this post Link to post Share on other sites
shaneg 0 Report post Posted January 28, 2012 (edited) i take it that ex japan ones arent as good as nz new then..?? Oh im not sure at all, just speculating about the e60. I know one gripe was to do with the satnav Gps conversion.. See here http://www.trademe.co.nz/motors/car-parts-...n-442595131.htm ^ is a forum member. Which may not seem that bad but its nice to be able to have full functionality of your car. If you decide to buy from kiwis cars, or any dealer id highly recommend to take it to botany motorworx to be throughly checked. Edited January 28, 2012 by shaneg Quote Share this post Link to post Share on other sites
khello 0 Report post Posted January 28, 2012 oh ok yep i did notice that all the sat nav would be unusable unless converted. good point on having full functionality of a nice new car. cheers will take that into consideration. Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 28, 2012 (edited) i take it that ex japan ones arent as good as nz new then..??Japan ones are always better spec'd than the NZ ones. The E60 "i drive" can be loaded with new software to convert GPS to NZ.As with the M62 the N62 leaks oil, the front cover gaskets and both rocker cover gaskets leak. Easy enough to remedy. Should mention the Singapore cars only need a software update, the jappas need a little more, still not hard to transfer though. Edited January 29, 2012 by Greg. Quote Share this post Link to post Share on other sites
RvT 9 Report post Posted January 28, 2012 hi guys, im new to the forum. i joined as i am in the market for a e60 545i. and what better place to get advice from a bmw forum!! i just wanted some help first of all in finding a decent one and also to get advice on what i should be looking for when i go to inspect etc also what i should be expecting to pay. i would really preffer a black one. Any help would be much appreciated guys. cheers Which part of NZ are you in as your profile is not filled out to tell us? Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted January 28, 2012 Japan ones are always better spec'd than the NZ ones. The E60 "i drive" can be loaded with new software to convert GPS to NZ. I believe there is still a hardware component as well as software that must be replaced. Also worth noting that the tv wont work once analog is turned off in NZ (which will be periodically in the next year or 2) here is another altho an 04, but NZ new and with NAV etc! http://www.trademe.co.nz/motors/used-cars/...n-409387856.htm when you see 2005 it may not actually be an 05 this is just the date of first rego. you need to check the VIN for the actual build date. Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted January 28, 2012 Do they still use different transmissions in the Jap ones this late? Those Jatco's weren't really that good. Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 28, 2012 Do they still use different transmissions in the Jap ones this late? Those Jatco's weren't really that good.Ha no they went out with E36s, they use the same ZF Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted January 28, 2012 Ha no they went out with E36s, they use the same ZF those improt 545 look pretty bsasic , i bet most new NZ 545 were pretty well specced. Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted January 28, 2012 those improt 545 look pretty bsasic , i bet most new NZ 545 were pretty well specced. For that price point ur not going to get full msport kit, seats etc unfortunately Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted January 28, 2012 For that price point ur not going to get full msport kit, seats etc unfortunately thats a good point Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 28, 2012 All the import ones that we've seen have been far better spec'd, NZ ones are quite boring with their spec sheets. Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted January 28, 2012 All the import ones that we've seen have been far better spec'd, NZ ones are quite boring with their spec sheets. probably due to the prices on the option list! Even now days on a 3 series NAV is over 7k (business nav now standard on 5 series) Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted January 28, 2012 3 series NAV is over 7k (business nav now standard on 5 series) Yes, and some toys like the visual reverse sensors, reverse camera and TV need you to spec Nav in the first place. Why can't they put TV there without the GPS bits for a change? Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 28, 2012 Why can't they put TV there without the GPS bits for a change?They do. Quote Share this post Link to post Share on other sites
khello 0 Report post Posted January 31, 2012 thanks guys for all the thoughts. im in the akl region so if you see anything that you think might be worth a look please tell me. thanks again cheers Quote Share this post Link to post Share on other sites
