Ben
Max clamp pressure OEM M20 Clutch
I just got off the phone to mp auto in upper hutt
they told me the max clamp they have seen from
a modified stock M20 pressure plate is 1900lb.
Has anyone got more than this?
Also is there some sort of guide for clamp vs hp/torque?
Waiato brake and clutch modified mine to 2094lb's.. (950kg)
Has it slipped on you yet?
What clutch disc did you use?
it all comes down to what diaphragm is used whats more important is surface area as in bigger diameter or multi clutch plates.
Havent run it yet with this new clutch. They relined the old clutch disc with a new organic center.
