charles28 142 Report post Posted February 4, 2012 Hi Guys, Today I had the cluster repaired, which means the pixels are now all working clearly, however I can now read a message that comes up every time I start the car, (even when the cars cold and hasn't been driven since the day before) The LCD Screen displays "Slow! Cat Overheat! when you turn on the ignition 1 click before starting the engine. Could this be a sensor on the cat converters causing this? Once driving the message doesn't re-appear. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 4, 2012 (edited) Thats normal. Cat overheat doing it's self test. Motor must run to carry out this test. If it comes on while driving you have a problem Edited February 4, 2012 by *Glenn* Quote Share this post Link to post Share on other sites
