krish 3 Report post Posted February 9, 2012 Hi Guys, Think my airflow is on its way out and need a good one from E46 330i Year 2000 dont know if that matters but from motorsport version thanks Krish 021 170 6025 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 9, 2012 Has anyone checked it for you properly with a scanner ?? Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted February 9, 2012 Go with glenns advice. Get someone to scan your DME for fault codes to start with, then do a load test on WOT to pick up how much airflow it registers it will be a KG/min value. From memory it should be around 600KG/min at WOT around 5k rpm. If it is faulty it may just need a clean with CRC contact cleaner ... note theyre very sensitive and are easily damaged hot film sensors. Quote Share this post Link to post Share on other sites
krish 3 Report post Posted February 9, 2012 Has anyone checked it for you properly with a scanner ?? Hi Glen, No they havent but seeing the prices out there I may need to pop down one lunch time to see you How much will a scan cost Thanks Krish Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 9, 2012 Hi Glen, No they havent but seeing the prices out there I may need to pop down one lunch time to see you How much will a scan cost Thanks Krish Give me a call first (09) 2722546 Quote Share this post Link to post Share on other sites
krish 3 Report post Posted February 10, 2012 Hi Guys, Think my airflow is on its way out and need a good one from E46 330i Year 2000 dont know if that matters but from motorsport version thanks Krish 021 170 6025 Hi Guys, Had scanned Air Flow stuffed so will need a new one Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 10, 2012 Hi Guys, Had scanned Air Flow stuffed so will need a new one Dont forget the thermostat & top hose as well Krish Quote Share this post Link to post Share on other sites
krish 3 Report post Posted February 12, 2012 Dont forget the thermostat & top hose as well Krish Thanks for the help Glenn Will be back once I have a game plan Quote Share this post Link to post Share on other sites
