krish
wtb: E46 330I AIR FLOW METER
Hi Guys,
Think my airflow is on its way out and need a good one from E46 330i Year 2000 dont know if that matters but from motorsport version
thanks
Krish 021 170 6025
Go with glenns advice.
Get someone to scan your DME for fault codes to start with, then do a load test on WOT to pick up how much airflow it registers it will be a KG/min value. From memory it should be around 600KG/min at WOT around 5k rpm.
If it is faulty it may just need a clean with CRC contact cleaner ... note theyre very sensitive and are easily damaged hot film sensors.
Has anyone checked it for you properly with a scanner ??
Hi Glen,
No they havent but seeing the prices out there
I may need to pop down one lunch time to see you
How much will a scan cost
Thanks
Krish
Hi Glen,
Thanks
Krish
Give me a call first :D (09) 2722546
Hi Guys,
thanks
Krish 021 170 6025
Hi Guys,
Had scanned Air Flow stuffed so will need a new one
Hi Guys,
Dont forget the thermostat & top hose as well Krish
Thanks for the help Glenn
Will be back once I have a game plan
