nath 174 Report post Posted February 20, 2012 Hi guys 2 issues: 1. The digital climate control in my car seems to have piss poor fan speeds compared to most cars. The fan seems to change speed at each increment of the display but there is really no point in having it below half display speed as it is just too weak there. Air con and all functions work fine. 2. The engine does not heat up very fast according to the display, and even if or when it reaches half way on the needle, it is possible to lower it back down by coasting at idle down a long hill for instance. I have had the thermostat out and tested for hot/ cold movement (albeit out of it's housing) which seems fine enough. It is however by no means new. Any suggestions? Cheers for any help Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 20, 2012 (1) Change pollen filter and recheck (2) Replace thermostat Quote Share this post Link to post Share on other sites
nath 174 Report post Posted February 20, 2012 Cheers Glenn will do and report back. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 20, 2012 What engine type does the E36 have ? Quote Share this post Link to post Share on other sites
nath 174 Report post Posted February 20, 2012 M44 318iS, No cracks or damage to plastic components, new clean coolant. Quote Share this post Link to post Share on other sites
bimmer boy 21 Report post Posted February 20, 2012 I had real weak fan speeds in my E36 too when changed the pollen filters and it was completely different. Fan was real strong after that although the filter was tricky to get to. Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted February 21, 2012 I agree with the others in regards to pollen filter having done mine just at xmas with the same problem, is a little tricky, i found the filter harder to get out then in strangely Brent did a good how to here... http://www.bimmersport.co.nz/forums/index....showtopic=14148 Quote Share this post Link to post Share on other sites
