Henry.tam24 0 Report post Posted March 1, 2012 Recently got a new 2007 320i and the reset/warning symbol (!) keep coming up. They said it was the tyres pressure because there was one new tyre put on and it takes time for it to go away. Is this correct? Please help! Quote Share this post Link to post Share on other sites
Gaz 1067 Report post Posted March 1, 2012 Do you have the owners manual? It should list it in there. I know in my e36 (!) means low brake fluid. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 1, 2012 It's the run flat system. There are a couple of different versions for resetting Google : BMW 320 reset run flat And select which is relevant to your car and follow the proceedure Quote Share this post Link to post Share on other sites
zenetti 0 Report post Posted March 1, 2012 Exactly what Glenn said. If you need help to do it you are welcome to pop in and see us and we can help out Quote Share this post Link to post Share on other sites
Henry.tam24 0 Report post Posted March 1, 2012 Thanks guys! I'll look in google. If I still can't sort it out, where is your shop? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 1, 2012 I would also advise getting yourself an owners manual relevant to your model. It's all in there Quote Share this post Link to post Share on other sites
