magno 0 Report post Posted March 16, 2012 started up the car this morning no probs, pulled out the driveway and soon realised it wouldnt rev over 1500 rpm, feels like a limiter surging as soon as it hits 1500, starts & idles steady no miss or backfires, this has never happened before, i've checked over intake plugs & vacuum lines visually and with ezy start, dash says coolant level & catalytic but those have been there for months, any ideas folks? Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted March 16, 2012 Blocked cat converter? That's one cause of such a problem. Heed the warnings on your dash... They're there for a reason. Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted March 17, 2012 yes check the cats , they block up . have had that problem before , undo a plug bolt on the manifold to release pressure. also is teh any fuel in the tank?? Quote Share this post Link to post Share on other sites
magno 0 Report post Posted March 17, 2012 plenty of gas in the tank, pulled O2 sensor from exhaust no change - just noisy, re-checked for intake leaks again - all good, pulled round plug from under Throttle Body & now it revs freely BUT idles at 1100 rpm. So, is this the TPS i've unplugged? it 's a module type box screwed to the underside of throttle body, What is the fix for this and can damage be done by driving like this? Long day, time for a beer, thanks people. Quote Share this post Link to post Share on other sites
rjac001 0 Report post Posted March 17, 2012 I would check the inlet side of engine throttle is not stuck... etc Quote Share this post Link to post Share on other sites
gtirdriver 0 Report post Posted March 18, 2012 plenty of gas in the tank, pulled O2 sensor from exhaust no change - just noisy, re-checked for intake leaks again - all good, pulled round plug from under Throttle Body & now it revs freely BUT idles at 1100 rpm. So, is this the TPS i've unplugged? it 's a module type box screwed to the underside of throttle body, What is the fix for this and can damage be done by driving like this? Long day, time for a beer, thanks people. Could be your air flow meter Quote Share this post Link to post Share on other sites
magno 0 Report post Posted March 19, 2012 dont think its the afm, if unplugged while running the engine cuts out, if unplugged & started engine starts & runs like normal but will not rev proper, with TPS connected the engine revs to 1500 then surges from 1500 - 2000 rpm and will not rev any higher, TPS unplugged the engine revs normal but idles high (1100rpm) and car is driveable. this has happened suddenly with no previous warning so im gonna replace suspect part this weekend & see how it goes, if anyone else out there has been through this problem - cause - solution i'd like to hear about it, could be handy for others too, cheers. Quote Share this post Link to post Share on other sites
Jo Blogs 11 Report post Posted March 21, 2012 yes check the cats , they block up . have had that problem before , undo a plug bolt on the manifold to release pressure. also is teh any fuel in the tank?? +1 on cats, Just had this issue on my E39. Blocked cat would not rev past 1500RPM and then stalled upon throttle release. Not to common on the 6's but mine has done 350,000KM now. Quote Share this post Link to post Share on other sites
