Venatus
Gearbox parts interchangeability?
Hey guys, wondering if anyone's ever tried this before : I'm needing to swap gearbox but my spare has the steel plate linkage whereas what's in the car has aluminum arm. They're both g260s, the casings and bolt patterns look the same, can I swap the rear end of the gearbox casing to change shifter styles as I don't have the steel plate? Any help appreciated
I think this is the part your after 25112225369
Easy enough to make your own
I take it you have an early model g260
That's an even better idea, thanks for that idea. Now to source one from BMW or attempt to make one poorly... :P
