efp0wa 0 Report post Posted March 29, 2012 Hi all, Just got a e46 318i and the only key that was provided with the vehicle is missing its internals and appears to have been damaged as it is glued together, the buttons are also missing. Is this altering the performance of the electrics, alarm, immobiliser etc? I intent to replace when I have a spare $500 for a new key. Quote Share this post Link to post Share on other sites
Guest Ari Gold Report post Posted March 30, 2012 If it has no EWS how is it starting the vehicle? Quote Share this post Link to post Share on other sites
efp0wa 0 Report post Posted March 30, 2012 If it has no EWS how is it starting the vehicle? Good question?... Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 30, 2012 (edited) It will only be the remote parts that are missing. The transponder micro chip is probably glued into the key or behind the reader coil on the column. BTW: When the door barrel breaks you will not be able to get into the car if the rear hatch has no manual key barrel in it. Edited March 30, 2012 by *Glenn* Quote Share this post Link to post Share on other sites
efp0wa 0 Report post Posted March 30, 2012 It will only be the remote parts that are missing. The transponder micro chip is probably glued into the key or behind the reader coil on the column. BTW: When the door barrel breaks you will not be able to get into the car if the rear hatch has no manual key barrel in it. Ok I opened the key and i see a small transponder glued onto the end of the metal peice of key. Haha, "When" it brakes? Excellent... I'll get a new key sorted. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 30, 2012 Haha, "When" it brakes? Excellent... I'll get a new key sorted. Yes... they BREAK... we do between 6 & 10 E46 & X5 door barrels a month. The blade is meant to be for emergency opening only. You should have a working remote key for daily use. Quote Share this post Link to post Share on other sites
NZ BMW 368 Report post Posted March 30, 2012 Yes... they BREAK... we do between 6 & 10 E46 & X5 door barrels a month. The blade is meant to be for emergency opening only. You should have a working remote key for daily use. Actually I think it is from lack of use, the mechanism get dried out from lack of lubrication. Then when someone actually goes to use it, it fails. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 30, 2012 Its more of a poor design issue really, just like the X5 door handle carriers. I've done 5 of those in 3 weeks Quote Share this post Link to post Share on other sites
