FIAT 131R 223 Report post Posted April 23, 2012 Wilwood Proportioning Valve $95.00 PLUS FREIGHT. This proportioning valve features a knurled knob with a fine thread shaft for precise pressure adjustments from 100 to 1,000 PSI. The Wilwood brand valve provides up to a 57% reduction inline pressure, the highest of any proportioning valve on the market. It has a compact and lightweight billet aluminum housing with black anodized finish. The dual mounting holes make for easy installation. The valve can be used to adjust from front to rear, side to side, or single wheel brake bias. This Wilwood Proportioning Valve is ideal for Street Rods Pro Street Street Machines Drag Racing Off Road The specifications are as follows: Max. pressure reduction - 57% Infinitely variable knee point - 0-1,000 psi Inlet/Outlet ports - 1/8" - 27 NPT Mount hole diameter -.25" Mount hole spacing - 1.00" Weight - 1/2lb ***This Item Is Brand New*** Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3037 Report post Posted April 24, 2012 Is this legal to be used in the E30 series ? ?? Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted April 24, 2012 Is this legal to be used in the E30 series ? ?? I am staggered that you would ask especially when you advocate abolishing all classes and just have Class B, or is that A or C or E30 series. See you have me confused now. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3037 Report post Posted April 25, 2012 You must be getting confused Big Fella - I haven't advocated abolishing anything, except maybe prohibition?? Quote Share this post Link to post Share on other sites
