mossline 15 Report post Posted April 29, 2012 Hi guys, can anyone distinguis what this noise could be? Recently had my engine mounts and gearbox mounts replaced and this noise has since started. Only happens in 1st and 2nd gear at low revs. Im praying its not something in the tranmission but im guessing it could well be. The noise is at the beggining of the video so any ideas would be great! Cheers Quote Share this post Link to post Share on other sites
mossline 15 Report post Posted April 30, 2012 Bump, anyone got any ideas or had a similar noise in theirs? Quote Share this post Link to post Share on other sites
Allanw 1079 Report post Posted April 30, 2012 I can't go on you tube at work, so will have to look later. I don't mind coming to work, it's the 8 hour wait to go home that's a pain in the butt. Quote Share this post Link to post Share on other sites
Allanw 1079 Report post Posted April 30, 2012 Sounds like a drive shaft vibration, and the bearing carrier or similar is vibrating against something sound like the body work, but itmight sound different because of the microphone. Maybe when the mounts were done, it has moved the position a bit??? Or something wasn't tightened. I had the same thing on deceleration is a subaru once, and the bearing carrier was loose on it's mount on one side. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted April 30, 2012 sounds like hanger bearing and rubber driveshaft coupling. also check the gearbox and engine mounts etc. get it on a hoist. can help with parts if needed thanks brent Quote Share this post Link to post Share on other sites
mossline 15 Report post Posted April 30, 2012 Cheers all, hopefully its NOT the gearbox! Off to mechanic tomorrow so will hopefully have all her woes sorted. Quote Share this post Link to post Share on other sites
Jono51 60 Report post Posted May 3, 2012 Hi guys, can anyone distinguis what this noise could be? Recently had my engine mounts and gearbox mounts replaced and this noise has since started. Only happens in 1st and 2nd gear at low revs. Im praying its not something in the tranmission but im guessing it could well be. The noise is at the beggining of the video so any ideas would be great! Cheers call me asap, don't drive it,pretty sure i know whats wrong Quote Share this post Link to post Share on other sites
cameronf123 0 Report post Posted May 25, 2012 call me asap, don't drive it,pretty sure i know whats wrongthis sounds like what my car was doing? an the it will now not move, i select D or R an i have no drive? any ideas? say my transmission is gone Quote Share this post Link to post Share on other sites
Allanw 1079 Report post Posted May 26, 2012 any ideas? Manual conversion time Quote Share this post Link to post Share on other sites
