BMRBOI 8 Report post Posted May 10, 2012 Hi Guys, So my fuel and temp light stopped working the other day on the 325i and my OBC displayed the tail light failure message. Apparently its pretty common (googled it) but with various causes. Anyone had this happen to them? I read somewhere the tail lights can short from corrosion and cause this situation, so I unplugged both of them and pushed the pedal with a new fuse and it blew it straight away. Looks like it will be a weekend of wire searching… any ideas?? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted May 10, 2012 brake light switchesw are a comon fail on e36 e34 etc. but normally they just dont work when the fail not blow fuses. also check if it s got a high stop light wired in that the wires are not shorting to the car body . also the wiring going to the number plate lights often fail and short out where they bend just under the boot lid left side. Quote Share this post Link to post Share on other sites
BMRBOI 8 Report post Posted May 10, 2012 Cheers Brent! I will also check the boot lid wiring loom, common place of shorting. brake light switchesw are a comon fail on e36 e34 etc. but normally they just dont work when the fail not blow fuses. also check if it s got a high stop light wired in that the wires are not shorting to the car body . also the wiring going to the number plate lights often fail and short out where they bend just under the boot lid left side. Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted May 11, 2012 You don't have a tail lamp full of water do you? Quote Share this post Link to post Share on other sites
BMRBOI 8 Report post Posted May 11, 2012 I'm pretty sure I dont. I checked my boot lid wire and it has a few cracks in the coating but I can't see anything rubbing. At least today is sunny so I can have a good look. You don't have a tail lamp full of water do you? Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted May 13, 2012 Did you pull the boot on the wiring well up and clear of the cables? My old low k E36 was in great condition, only issue was the boot central locking stopped working one day. Checked the wiring, had to pull the boot up a fair way, and sure enough had one wire completely snapped and another 3 bare. Quote Share this post Link to post Share on other sites
