Etwenty1 45 Report post Posted May 13, 2012 have picked up this tidy little 318i, changed the crank seal and noted that the belt layout looked a bit odd. The alt belt was on an angle. On reassembly i cant get it back together any other way. Wondering if the belts on it are the wrong size or if the alt is mounted crooked. Does anyone have a diagram of the right belt layout? Quote Share this post Link to post Share on other sites
nath 162 Report post Posted May 13, 2012 I assume you mean that it is skewed around the vertical axis? Mine was, the rubber bushes in the alternator mount had gone soft. a temp fix was to remove them and reinstall so that the pressure is now on the 'good' part of the rubber. Or just get new ones or whip some up from nylon. Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted May 18, 2012 I assume you mean that it is skewed around the vertical axis? Mine was, the rubber bushes in the alternator mount had gone soft. a temp fix was to remove them and reinstall so that the pressure is now on the 'good' part of the rubber. Or just get new ones or whip some up from nylon. pics attached. Looks like the alt has rotated on stuffed bushes? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 18, 2012 Get some delrin or similar material ones made up. The genuine ones are useless Quote Share this post Link to post Share on other sites
