KwS 2448 Report post Posted May 28, 2012 (edited) On a kinda related topic, what's the deal with hids and headlight washers? My e39 has oem factory xenons but no washers? retrofitting the hid Hellas on e36 didn't require washers either? Had those Philips blue halogen bulbs in my e36 and they were worse than sh*t for output. Looked nice thought. I ignored the check control warnings on my old e36 too, until one day I was rolling down the motorway as it was getting dark, in rush hour traffic and found I had no brake lights at all. Sorted that out and never ignored check control since. If you get a lot of rear light warnings, check the boot wiring harness. If you haven't already I would bet on broken wires in there. Edited May 28, 2012 by KwS Quote Share this post Link to post Share on other sites
m2geek 4 Report post Posted May 29, 2012 On a kinda related topic, what's the deal with hids and headlight washers? My e39 has oem factory xenons but no washers? retrofitting the hid Hellas on e36 didn't require washers either? Had those Philips blue halogen bulbs in my e36 and they were worse than sh*t for output. Looked nice thought. I ignored the check control warnings on my old e36 too, until one day I was rolling down the motorway as it was getting dark, in rush hour traffic and found I had no brake lights at all. Sorted that out and never ignored check control since. If you get a lot of rear light warnings, check the boot wiring harness. If you haven't already I would bet on broken wires in there. I have a deal-installed aftermarket high-stop - which is spliced into my right tail lights and IMO is rather micky-mouse, so that is likely the reason I get brake-light warnings. My left rear light has what looks like calcium build up on the contacts which is likely causing my Tail light warning lol. As for the warning RE Low beam - whoknows, it did it with OE, Non OE, and now the dreaded X-lights (haha) I once blew a fuse fiddling with the rear lights trying to stop the damn warning, so I haven't really bothered since. Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted May 29, 2012 I'd still check the boot lid wiring harness. Real common problem. http://forums.bimmerforums.com/forum/showthread.php?t=79896 Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted May 29, 2012 Well took the car for its WOF this morning. Passed - Clear and without warnings, no mention about the Xenon.. The guy said the beamform was spot on and level was fine, I asked the specifically to check for that. Yay me Wouldn't take WOF as any kinda guidance on whether or not it is correct, took a Falcon for a COF (comercial WOF) at VTNZ and they asked if it was front or rear wheel drive after being under the car! Quote Share this post Link to post Share on other sites
m2geek 4 Report post Posted May 29, 2012 I'd still check the boot lid wiring harness. Real common problem. http://forums.bimmerforums.com/forum/showthread.php?t=79896 Just been out n had a look, it looks fine Inside the boot, and running thought the grommet to boot Lid looked ok too Quote Share this post Link to post Share on other sites
m2geek 4 Report post Posted May 29, 2012 Wouldn't take WOF as any kinda guidance on whether or not it is correct, took a Falcon for a COF (comercial WOF) at VTNZ and they asked if it was front or rear wheel drive after being under the car! LOL... I would have said its propelled by pixies or hopes n dreams... Quote Share this post Link to post Share on other sites
nizalb70 0 Report post Posted May 29, 2012 I'd still check the boot lid wiring harness. Real common problem. http://forums.bimmerforums.com/forum/showthread.php?t=79896 +1 had my harness replaced works fine now. Quote Share this post Link to post Share on other sites
m2geek 4 Report post Posted May 29, 2012 Woot - my LED park lights arrived, just put em in ^^^^ SOOO much nicer than incandescent bulbs! Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted May 29, 2012 Better update your sig. Be aware that the LED may strobe when the LCM checks the bulbs. My LEDs on the E39 angel eyes did (I've fitted a relay for the moment to diconnect them from the circuit when not switched on) Tail and brake lights can trigger warnings if they are old too - the filiments become high resistance and trigger the warnings - justhad it on the E39. Quote Share this post Link to post Share on other sites
m2geek 4 Report post Posted May 29, 2012 Better update your sig. Be aware that the LED may strobe when the LCM checks the bulbs. My LEDs on the E39 angel eyes did (I've fitted a relay for the moment to diconnect them from the circuit when not switched on) Tail and brake lights can trigger warnings if they are old too - the filiments become high resistance and trigger the warnings - justhad it on the E39. Will make new sig when the LED Fog lights arrive heh.. Took to my tail lights with CRC contact cleaner - so far, no difference I blame the funky wiring job on the high-stop. Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted May 29, 2012 LTSA Ruling Clearly states just changing the bulb to HID is illegal Insurance assessor may spot these if you are ever in a crash and refuse claim, remember that means they will not pay for the fence / powerpole / Ferrari that you may hit !!! Quote Share this post Link to post Share on other sites
m2geek 4 Report post Posted May 29, 2012 LTSA Ruling Clearly states just changing the bulb to HID is illegal Insurance assessor may spot these if you are ever in a crash and refuse claim, remember that means they will not pay for the fence / powerpole / Ferrari that you may hit !!! ^^^^ Seen it, Read it, Discussed it, Solving it with new lenses. Quote Share this post Link to post Share on other sites
nizalb70 0 Report post Posted May 29, 2012 (edited) LTSA Ruling Clearly states just changing the bulb to HID is illegal Insurance assessor may spot these if you are ever in a crash and refuse claim, remember that means they will not pay for the fence / powerpole / Ferrari that you may hit !!! Have had my old car written off and insurance assessor found it to be irrelevant with the aftermarket HID kit but hey that was just my case. Edited May 29, 2012 by arcanix Quote Share this post Link to post Share on other sites
