charles28
WTB: Manual Conversion Kit
Hi Guys,
I'm looking for all the parts to convert my 1989 E30 325i to manual, its running fine as an automatic, however I know these cars are much better with a manual gearbox (used to have a manual one so I know).
Keep in mind I'm in Christchurch, so you need to be willing to put this gear on a Pallet and have it bulk freighted to me if your out of Christchurch.
Charles
Have now found most of the parts from forum member Euro_M325i
I still need the gearshift knob and boot, but can this be used with the automatic surround? or do I need to find one from a 4 dr manual car?
you can use the auto one, you just take away the plastic bit that has PRND321 on it so its just a hole. the shifter ball and boot you can get both from BMW though the boot may be cheaper to make yourself not sure
