euroriffic 626 Report post Posted June 17, 2012 Had a screwed ignition barrel and have just replaced after a nightmare to get it out. New one went in fine, turned into off position and took key out but now the wee security flap inside it won't let me put the key back in at all! Any Ideas guys? Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted June 17, 2012 do you have trans cable screwed into the side of the barrol?? Quote Share this post Link to post Share on other sites
euroriffic 626 Report post Posted June 17, 2012 Doesn't have it due to being a manual. I've got it to work now after prying it to the side abit but it's still quite difficult to get key in but only when barrel is in the column. Fine when it's out. Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted June 17, 2012 Doesn't have it due to being a manual. I've got it to work now after prying it to the side abit but it's still quite difficult to get key in but only when barrel is in the column. Fine when it's out.maybe you haven't got it screwed/clamped up properly to the sterring colum Quote Share this post Link to post Share on other sites
euroriffic 626 Report post Posted June 17, 2012 It's not too bad now. Mite just need a bit of use Quote Share this post Link to post Share on other sites
