Palazzo
E36 coupe door handle
Ok, got in the car today (actually I didn't) and the door handle raised as normal, but did nothing. Window didn't drop as it should and door wouldn't open. Opens ok from inside, window drops etc?
Problem? Fix? Time and cost?
Cheers.
broken outside door handle mech (quite common)
takes about 1-2 hrs to replace
2nd hand part $50-60 etc
just make sure you get the correct type so you can swap over your key barrol
