Wickmyster 0 Report post Posted July 16, 2012 These number I found for the E30, are they the same for the E36, and what is mising?? •Upper timing cover gasket set 11141721919 •Lower timing cover gasket set 11141721802 •Front profile gasket 11141247837 •Rocker cover gasket set ( 11121721876 profile gasket, 11121721475 spark plug chamber seal - lollipop shape, 3 off 11121721476 spark plug chamber - O shape) •Timing chain 11311247160 •Crankshaft sprocket 11211247338 •Camshaft sprockets (2 off) 11311721887 •Front crankshaft oil seal 11141439570 •Thermostat housing gasket 11531721172 •Tensioner guide rail 11311727342 •Guide rail 11311247470 •Timing chain tensioner 11311743187 with its sealing washer 07119963355 Quote Share this post Link to post Share on other sites
jeffbebe 1568 Report post Posted July 16, 2012 These number I found for the E30, are they the same for the E36, and what is mising?? •Upper timing cover gasket set 11141721919 •Lower timing cover gasket set 11141721802 •Front profile gasket 11141247837 •Rocker cover gasket set ( 11121721876 profile gasket, 11121721475 spark plug chamber seal - lollipop shape, 3 off 11121721476 spark plug chamber - O shape) •Timing chain 11311247160 •Crankshaft sprocket 11211247338 •Camshaft sprockets (2 off) 11311721887 •Front crankshaft oil seal 11141439570 •Thermostat housing gasket 11531721172 •Tensioner guide rail 11311727342 •Guide rail 11311247470 •Timing chain tensioner 11311743187 with its sealing washer 07119963355 Check on www.realoem.com Best to input the last 7 digits of your car's VIN to ensure your looking at the right parts catalogue. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 16, 2012 If your going to go to all that trouble, I would be also doing the inner timing cover gasket as well, which involves removing the sump too Quote Share this post Link to post Share on other sites
Wickmyster 0 Report post Posted July 17, 2012 http://www.realoem.com/bmw/showparts.do?mo...hg=11&fg=25 DO 6 17 8 13 and 10 all ornally wear out??? Quote Share this post Link to post Share on other sites
