Michael.
Left hand thread metric engineering hex nuts
I've been hunting around for a local source of left hand metric engineering nuts.
Started ringing around a few local stores in Penrose/Onehunga today but no such luck.
I'm specifically after a high tensile M12x1.25 Left hand thread hex nut, rather try source it locally than find one from overseas.
Any ideas of a store that might have such an item?
Steelmasters.
They will make it if they don't have it.
It will cost however.
Try ringing EDL or Anzor in E/T, they supply us at work at seem to have almost everything.
If not they should point you in the right direction.
And if you ask for a sample you'll probably get it for free too
  Steve K-B said:
These guys may not have it but they will point you in the rite direction
www.boltshop.co.nz/
From the dealings ive had with them, I think there awesome
They had one! Thanks for that Steve.
I had no luck at steelmasters or EDL in the end.
Thanks for your help guys.
