Rip_it_up 0 Report post Posted July 25, 2005 Hi guys, just wondering if someone could shed some light on a problem i have with my automatic trans, the button to shift the stick to drive, park etc is broken, and its REALLY hard to move the stick to drive, park, reverse etc, like you have to put alot of force on the stick to move it, is this normal? or is it because the button is broken? is the trans buggered or on its way out? cheers guys Quote Share this post Link to post Share on other sites
bmwsparkle 3 Report post Posted July 25, 2005 never heard an auto stock being hard to move because of condition of trans, so im guessin its just the stick, mines on the way out and it dosent do it ... Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted July 25, 2005 Rip_it_up said: Hi guys, just wondering if someone could shed some light on a problem i have with my automatic trans, the button to shift the stick to drive, park etc is broken, and its REALLY hard to move the stick to drive, park, reverse etc, like you have to put alot of force on the stick to move it, is this normal? or is it because the button is broken? is the trans buggered or on its way out? cheers guys what model of car is it .i had sticky gear lever when it got hot in a 730i v8 , because coolant got into the trans from the radiator . and made a little plastic lever stick inside its aluminum housing . Quote Share this post Link to post Share on other sites
Rip_it_up 0 Report post Posted July 25, 2005 its a 1993 e36 bmw, could it be beacuse the button to push to change gears is broken? Quote Share this post Link to post Share on other sites
