bellicose
V.S Motor are at it again.
Crazy! No way that setup will fit in a car though.
Just build a car around it mate.
Haha very true, with 1800bhp you would wounldn't ya.
Holden ute's have the same amount of power don't they?
IMHO - what would one use this engine for? It won't go in a car because any gearbox would blow to bits with that amount of power, it's size would prohibit it fitting into a car. I kinda don't see the point of this engine?
Isn't a lot of things automotive are built just because whoever that built it can? There's a 6-rotor Rotary engine somewhere on YouTube, Subaru had a flat-12 prototype, there was a tiny, fist-size V-12 hand-made engine mentioned couple of months back. Good on them for trying and push and see what things will go.
I was hoping to see some white hot exhaust manifold, I guess they didn't run it long enough for that to happen.
Mine will be almost close when it's done. (Block, crank & rods are already for the other bits to arrive, very slow process but worth the wait.) Very similar setup to this but without purple paint.
Does there need to be one haha.
We used to reliably get 1100hp throught a manualised TH400.
2 spd hydraglide would handle that power no sweat.
Do you mean Powerglide? (MOPAR box)
Edit for spelling.
Edited by bellicose
Guest Ari Gold
Yep. I don't think bolting a Harley Davidson to the back of the motor would be a good idea :ph34r:
Be the only way to make a "potatoe" fast.
And the upside would be the handling & stopping abilities of said "potatoe" wouldn't change.
Because they have niether of those atributes standard haha.
