Arma 134 Report post Posted August 28, 2012 (edited) I've been talking to Ray (Hell bm) about a possible engine conversion sometime in the near future, which he said Hell BM would be able to do. (Idea was to swap m54b22 2001 520i with a m54b30 from a 2001 530i and donor parts - cost would considerably be less than to buy another car). What I was wondering is whether I need some form of certification/approval (e.g. LVV) in order to be able to pass a WOF after the engine swap? Note: My apologies if there is another topic covering this, I couldn't find any. Edited August 28, 2012 by Arma Quote Share this post Link to post Share on other sites
polley 916 Report post Posted August 28, 2012 Technically yes you do, no one will notice though. Quote Share this post Link to post Share on other sites
Michael. 2312 Report post Posted August 29, 2012 Yeah like what Troy said, yes you do, but chances are very few people would pick up on it, unless they checked the engine numbers With the LVV cert it would require one as you've replaced the engine with a larger capacity / more powerful engine. Granted you'd be using factory parts it would be a pretty easy cert to acquire... Quote Share this post Link to post Share on other sites
Arma 134 Report post Posted August 31, 2012 Technically yes you do, no one will notice though. Yeah like what Troy said, yes you do, but chances are very few people would pick up on it, unless they checked the engine numbers With the LVV cert it would require one as you've replaced the engine with a larger capacity / more powerful engine. Granted you'd be using factory parts it would be a pretty easy cert to acquire... Alright cool, thanks guys. Quote Share this post Link to post Share on other sites
